Has anyone done this? More specifically in a beretta or under the $A1 mask? I know there is an option for 4 speed tranny, just wondering if it'll work.
4t60-e on OBD1?
it is yup, its very simmilar to the 727 and 730 except the i/o are different.
the 16149396 has extra sram on it for the trans control code
someone claimed that have used 8f code on it but i said b.s. and they didnt prove it so im not sure what would be needed to make a1 work on it
may be as simple as re pinning
but then youd have the problems of no trans control code in the a1
I've run a 9396 ECM on my 94 Beretta (3100/4T60E). Just had some tuning issues that we could never resolve. I gave up on the project, sold everything and then someone brought up an issue with keeping the sensor grounds together per the wiring diagram. Did that cause the issues we (Ben and I) were having? Most likely, but not for certain. I could probably dig up all the documentation I have on the project. Hell, alot of it is probably still on the forum somewhere...-Brad-
Originally posted by sil View Postit is yup, its very simmilar to the 727 and 730 except the i/o are different.
Originally posted by sil View Postthe 16149396 has extra sram on it for the trans control code
DFI and ECM - 16149396 vs 1227727 - While searching for some info I stumbled across this information. If this is true does that mean that I can run $8D on a 16149396 ecm? Info found at Untitled Document (http://www.w-body.com/inside-stuff/ecm-pcm.html) ...Cars with the 91-93 3.4L DOHC V6 use a 16149396 PCM, which is...
I did not see the bs comment, but I still have no idea how to "prove" to you that my TGP with $8F code runs well using a 9396, or the TPI in the vette runs fine using $8D in a 9396.
Originally posted by sil View Postso im not sure what would be needed to make a1 work on it
may be as simple as re pinning but then youd have the problems of no trans control code in the a1
oh, must have been thinking it "bs thoughts" lol
ill have to burn an 8f chip and throw it in my 9396
so you didnt do any re pinning of any wires at all ?
that would be great if i did get it working, much less work NOT swapping ecus
allthough i would need a different tranny... manual swap perhaps
or piggy back another 9396 lolLast edited by sil; 12-13-2006, 03:25 AM.
