The maf in my '85 camaro went out recently so I grabbed an '88 maf from a junk yard and hooked it up, but it wouldn't idle. Maybe I grabbed a bad one, but they're compatble aren't they? My parts store lists them under the same number but there's two versions of it, one with a 'funnel' around the wire and one without (mine).
MAF help
MAF help
3.4 block converted to roller valvetrain with 220/225 cam on 115 lsa, '769' heads with 3500 valves, LS6 springs & porting, twin T04E turbos, 3500 plenum with ported 3400 lower & 'short star' 65mm throttle.Tags: None
