So I've got a bit of a stumble on tip-in, and I've finally got around to messing with the AE to try to fix this. According to my wideband, it shoots rich for a split second (~11-12:1), then goes way lean (19-20:1) So it would seem to me that the AE is too much initially, but it decays to quickly.
This is my OBD1 3400, tuning with Tuner Pro. In TP, I have the following AE tables available.
I've worked a bit with the "AE Async Pulse Multiplier Vs. Delta TPS" table. Increasing values in this causes to to go even richer and then not quite as lean. But it doesn't appear that there are any tables available to control the rate at which the AE decays.
in GMPCM, there are a few additional tables, so maybe those are what I need to mess with?
Code:
AE Async Pulse Multiplier Vs. Delta TPS Accel Enrich Factor Vs. AE Pulse AE Async Pulse Multiplier Vs. Coolant Temp. AE Async Pulse Multiplier Vs. Baro AE Async Pulse Multiplier Vs. MAT
Code:
TIME-OUT REDUCTION FACTOR TIME-OUT REDUCTION FACTOR MULT
