is it just me or is there no ccp constant in tunerpro
ahh i miss gmpcm, to bad its author is a douchbag
DF.xdf
![Neutral](https://www.60degreev6.com/vb5/core/images/smilies/icon_neutral.gif)
DF.xdf
%%CONSTANT%% 000002 UniqueID =0x3E3C 020005 Title ="Number of Cylinders " 020011 DescSize =0x0 020010 Desc ="" 020020 Units =" " 020100 Address =0x9 020200 Equation =1.000000 * X + 0.000000,TH|0|0|0|0| %%END%% %%CONSTANT%% 000002 UniqueID =0x3E3D 020005 Title ="Initial Spark Advance " 020011 DescSize =0x0 020010 Desc ="" 020020 Units ="Deg. " 020100 Address =0x21 020200 Equation =0.351563 * X + 0.000000,TH|0|0|0|0|
03CC A0 160 KCCPTMP 80 DEG C DISABLE CCP IF COOLANT < THIS 03CD 01 1 KCPVST1 0.3 MPH ENABLE CCP IF MPH >= THIS (CCP OFF) 03CE 0F 15 KCCPTPSU 6 % ENABLE CCP IF TPS >= THIS (CCP OFF) 03CF 0C 12 KCCPFLWH 3 GM/SEC ENABLE CCP IF FLOW > THIS (CCP OFF) 03D0 00 0 KCPVST2 0 MPH DISABLE CCP IF MPH < THIS (CCP ON) 03D1 05 5 KCCPTPSL 2 % DISABLE CCP IF TPS < THIS (CCP ON)
085F 44 68 KAFOPT1 %01000100 N AIR FUEL OPTION FLAG WORD 1 BIT DESCRIPTION BIT0 1 = BPW MOD; 0 = A/F MOD SELECTED BIT1 1 = CALCULATE EXECUTION TIME IN EACH BRANCH BIT2 1 = CALCULATE 'BPW AT IDLE' AS FUNCTION OF AIRFLO BIT3 1 = VATS ENABLED BIT4 1 = NORMALLY OPEN FAN #2 REQUEST BIT5 1 = MATDEG FOR F132 TABLE; 0 = INLETTMP BIT6 1 = MULTIPLY DE DELTA MAP TERM BY NTRPM BIT7 1 = MANUAL SHIFT LOGIC; 0 = AUTOMATIC TCC LOGIC
