I searched a little but haven't come up with much. Has anyone looked further into using this computer, or has anyone tried converting to it?
3100 EEPROM/MAF computer '95 era, A-body
Brian
3400 SFI V6, 4T60e
'08 Chevy Trailblazer SWB 1LT "Smart Package"- LH6 5.3L V8/4L60e, A4WDTags: None
Oh yeah I haven't ruled out OBD2, but the more I look into the conversion, the more of a PITA it looks like. I may have to lay the car up for several days, which isn't easy lately.Brian
3400 SFI V6, 4T60e
tunercat can tune the odb1.5 95 crap? Interesting... Is it for A body only though?sigpicNew 2010 project (click image)
ah that's right it had a removeable chip w/3100. I can't remember who tried to adapt that..sigpicNew 2010 project (click image)
3400-Modified did it. Not sure if he ever got everything worked out. I have one of the ECMs sitting in my basement. Just never got around to messing with it...-Brad-
what model buick had the ecm with the removable chip in it. or was it just buick for that year in general.sigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
Hey Hey Hey! I want in on this! I've got too many plans and I'm about to be stomped if I can't get this damn ecu re-burned, lord knows how many times till it's right....
Isaac, Buick and Olds ussually go hand-in-hand when it comes to wiring and ecu's. I'll pull some part numbers from the factory tom. and see what we got. BRBsigpicHow to make High performance Emissions:
if anyone can find out before tomorrow midday im going to the junkyard so ill pull what i can find.sigpic
99 Grand Am GT
94-95 buick century. The thing looks like someone did a 3100 swap where a 3300/3800 used to be. The whole setup is simmilar. Maff setup, wring and all.
Code looks 3800ish to me.
ONly thing this thing is good for is SFI and trans controll. BUT what style of trans setup? INternal electrical setup of the 60-e changed around that year. SFI...who needs that anyway unless your looking at big power but you also need a bigger maff...which one to get? Not worth it to me.
You'd be better off with a auto TDC ecm if your looking for electronic trans controll for your auto powered little hot rod.88 Beretta GTU turbo . 90 Black ASC/McLaren TGP, awaiting 4t80. 2003 Grand AM se 3400/4t45 daily grind.
would i need the wiring harness from the car or is this mor or less a plug and play type of thing. OT the upper intake is different on theses cars too its got a 3800 ish type of throttle body setup. i snagged the computer and the othe box that sat ontop of it.sigpic
99 Grand Am GT
Turbo: not only do we need trans control, but some way to tune our bastard gray year ODB1.5 whatever crap.sigpicNew 2010 project (click image)
All the buicks of 95, except the century, have a the same plugs as our grey area nightmares. 3 32-pin connectors. The century has 2 32-pin and 1 24-pin connector, and they look really differant in their pics. It might be possible to just do a connector switch by knocking out the pins and putting them into the right holes on the proper connector blocks. I'm looking for the factory part numbers now to the century connectors. Then all we would have to do is add a few wires for the MAF.
12045575 Black 32-pin
12047946 Black 24-pin
12045471 Orange 32-pin
Now where do I get a 65mm MAF for a 95 Buick Century so my 3400 can breath?Last edited by 95SleeperAcheiva; 07-15-2006, 11:57 AM.sigpicHow to make High performance Emissions:
