Will my computer reject boost?
  • #76
    Why bother with an FMU?
    Why not just get any 7727 or 7730 and drop in the chip from a 1989 Turbocharged GTP. Use the same sized injectors & Turbo as the GTP and you are pretty damn close to dialed in. No FMU or AFPR or timing box, just a factory ECU designed to run boost right out of the box. Later if you want to go up on boost or turbo size, you can modify the calibration tables using this guy's software:
    Login to your account and start to play all interesting and exciting games at RubicPlay.
    Read all of the threads on that site, particularlty in the OBD1 section, and that should give you a pretty good idea of what to do.
    Regards,
    Brian C.
    • #77
      Sorry to bring something else back from the dead, but with I didn't see any mention of me here and i thought I would add that I'm still running a 1994 3100sfi computer on my supercharged z26. With a 255lph fuel pump, vortech SFMU (75 - 80psi fuel pressure at WOT), and about 96 to 98 or so octane I was not getting knock or leaning out this last summer. You can run this computer, but it is not optimal. I ran with 7psi and no initercooler.
      1988 Fiero GT 5spd
      1999 Regal GS
      SOLD 2000 C5 Coupe M6
      RIP 1994 Beretta Z26 - M90, 3400, MSV3, 5spd
      • #78
        How much boost are you planning on running?
        95 Beretta Z-26
        Don't need nitrous to go fast.
        Global peace through deadly force!
