I have a thread posted in swaps, but this is probably the better forum for my next questions...
I have a 3400 out of a 99 pontiac montana installed in desert buggy with a manual vw type tranny. It has all of the basic engine function sensors/systems installed (MAf, MAP, coolant, oil pressure,IAT, IAC,TPS,DIS ign, front o2 sensor) The PCM is the OBD 2 unit out of the van.
It does not have any emmissions/egr stuff (strictly for off road use) and no VSS. The latter is what worries me.
Will it ever run right without the VSS?
If so, can I make it work with the dhp tuning software and OBD 2, or should I switch out to a OBD1 system?
If so, which year used MAF and DIS?
I appreciate any and all help...
Thanks
Frank
Thanks
Frank
