I'm converting my 95 obd 1.5 to pre 94 obd 1.
I am going by brads guide here.
I managed to pick up a computer with the wiring harness attached. I cut it about 18 inches down so i have 18 inches of wire to play with. I got it from a grand prix with the 3.1.
I got the 7727 one.
my quick question is, now what do i need now from this quoted parts list. If at all possible just quote the part of my quote that I need. Very simple. Thanks. So i have the computer with the plugs attached with 18'' of wire on it.
Let?s first cover the basics. This document is being written to allow a GM 16149396 ECM to take the place of a GM 16156397 PCM. The 16149396 ECM was used in 3.4 DOHC equipped cars in the early to mid-90s. They are identical to the 7727/7730 ECM
16149396 ECM: You can usually one of these floating around eBay for around $30. If not, head to a junkyard to pick one up. They are found in cars with a 3.4 DOHC, and also 93 Grand Prix?s with the 3.1L.
16149396 Harness Plugs: Most eBay ECM auctions don?t include the harnesses, so you?ll have to go to a junkyard and pick these up. Some yards won?t let you just take the connectors, so you might have to do some searching or just get the entire harness. If you can just get the plugs, get ~24? of wiring to get with the plugs.
16156397 Harness Plugs: These are available from GM Parts Direct for ~$112 (plus S&H). You will need all of the following parts:
o 12129025 (x3) : $4.26 each
o 12129021 : $0.97 each
o 12129022 : $0.97 each
o 12129023 : $0.97 each
o 12129028 (x3) : $2.13 each
o 12084913 (x ~75) : $1.20 each, come in packs of 5 ($6.00/pack)
16156397 PCM Plugs: These are the actual PCM connectors that are mounted to the circuit board inside the PCM. You can get these from the Power and Signal Group, and most likely for free! They are a large-quantity supplier, but do send out free samples of products to see if they will meet the customer?s needs. Do a search for these part numbers and then just add them to your Sample Cart. Once you are done, just follow the remaining steps to get them sent to you for free!
o 12129008 , 12186041 , 12186043
16 gauge wire: You can get this just about anywhere, but electronic supply stores (such as Radio Shack) are your best bet. You don?t need more than 1 color, but several colors will make wire identification slightly easier.
