what is the best tuning program out there to program the stock pcm?
tuning program qestion?
what about a 93 dohc running on a 90 3.1 TGP bin?
i'm useing tunercat, but haveing problems with excive rev'n sometimes during coasting and idleing, and i can;t seem to be able to cal the right BPC constant for the #36 injectors04 Escalade 6.0L
08 Z06
96 Blazer SFA
Firestone...I would look for the most compleat code mask for your cars chip that has the things you want to change. Then decide which program has it. You'd also want to find a compleate ALDL program for your car also...no sense in modding if you don't know if it ain't working.
Const
. If you have..then look into the main VE tables...or other supporting tables. Well what have you done so far? You also have to mod the DE (decell tables) too..they affect base palse directly too.88 Beretta GTU turbo . 90 Black ASC/McLaren TGP, awaiting 4t80. 2003 Grand AM se 3400/4t45 daily grind.
Originally posted by sappyse107the fuel constant doesn't do shit other than gas milage calcs for a dash puter to spit out at you.
Cliff Scott
89 BerettaGT
04 AleroGXCliff Scott
89 BerettaGT
04 AleroGX
I got this from a P4 PFI for a 2.0 turbo..might want to get the one from tunercat for the 8f to read up on its workings..
Base pulse width calculation
The base pulse width calculation for fuel delivery:
BPW=BPC*MAPP*T'*A/F'*VE*F33c*BLM*DFCO*DE*CLT*F77
Where:
BPW= BASE PULSE WIDTH
BPC= BASE pulse constant term
Mapp= Manifold pressure term
T'= Inverse temperature term
A/F'= inverse air fuel ratio term
VE= Volumetric efficiency term
F33c= Battery voltage correction term
BLM= Block learn correction term
DFCo= decel fuel cutoff term
DE= Decel enleanment term
CLT= Closed loop correction term
F77= TURBO BOOST MULTIPLIER
Heres why the BPW vs EGR is the closes to Get the BPW right on upgraded INJECTORS..
The following computation shall be used to obtain the airflow (1bit=0.25 grams/sec.) through the engine
Air flow= BPWM*KAIRF~w*218*KNUMcyL*25*AIRFUEL*NTPRMx32
Where:
BPWM= Base pulse width for EGR
KAIRFLOW= Air flow multiplier
KNUNCYL= Number of cylinders*32
Air FUEL= engine running air fuel ratio*IO.
NTRPMX= computed engine rpm scaled 25 rpm/bit.
heres the DE tables and what not...don't know where I got thise...
8B28 04 4 1.6 %TPS DECEL ENLEAN DELTA THROT ANGLE THRES
8B29 10 16 5 KPA DECEL ENLEANMENT DELTA MAP THRESHOLD
8B2A 50 80 1 SEC AE TO DE BLEND TIME
8B2B B0 176 0.68 MULT AE TO DE INITIAL BLEND MULTIPLIER
8B2C 08 8 0.03 MULT AE TO DE BLEND MULTIPLIER DELTA
8B2D 80 128 1.6 SEC PE TO DE BLEND TIME
8B2E 60 96 0.375 MULT PE TO DE INITIAL BLEND MULTIPLIER
8B2F 03 3 0.01 MULT PE TO DE BLEND MULTIPLIER DELTA
8B30 80 128 0.5 MULT D.E. MULTIPLIER WHEN TCC LOCKED
8B31 80 128 1 MULT D.E. MULT WHEN CONV OT PRESENT
DECEL ENLEANMENT FACTOR VS. NUMBER OF INJECTS IN DE
8B32 58 50 40 30 20 18 14 10 10 10 10 10 10 10 18 1C 20
DECEL ENLEAN FACTOR VS. DELTA THROT
8B43 16 20 30 40 48 50 50 50 50 50 50 50 50 50 50 50 50
DECEL ENLEAN TERM MULTIPLIER VS. NMPH
8B54 00 00 00 00 00 80 C0 E0 FF
DECEL ENLEAN TERM MULT VS. NMAPLD
8B5D 28 28 30 30 38 38 40 40 40 40 40 40 40 30 20 10 10
DECEL ENLEANMENT FACTOR VS. DELTA MAP
8B6E 08 0C 10 14 18 20 24 28 30 40 40 40 40 40 40 40 40
DECEL ENLEAN TERM MULT VS. COOLANT
8B7F 10 10 10 10 10 30 50 50 40 40 40 40 3C 38 30 20 1088 Beretta GTU turbo . 90 Black ASC/McLaren TGP, awaiting 4t80. 2003 Grand AM se 3400/4t45 daily grind.
