need help with a pcm
  • need help with a pcm
    ok i have the whole wiring harness and the pcm for a 95 or 96 not usre which out of a Cutlass Ciera.I was wondering hwo can i tell form the numbers on it what year it is and how can i tune it with out geting a chip.any help would be grate
    RE: need help with a pcm
    Its a 95/96, therefore its a FLASH-type PCM, and therefore no easy way to tune it. Around that time frame, not too many people even do re-flashes, but those that do usually charge around $300. Don't expect it to be cheap at all...
      Can't DHP help you out if you have a '96?
      1995 Monte Carlo LS
        ok iam lost on what this pcm is it has a chip you can remove i have pics i can show anyone but i do not know how to put them on here
          here are some pic i hope that you all can see them
          well tell me what you think what this thing is
            ok here are some more pics
            more pics
              RE: ok here are some more pics
              Its the knock sensor filter. The actual EEPROM is soldered to the board...
