hi, hope someone can help. 92 regal, 3.1, code 43, i just replaced the knock and that did'nt do the trick so i'm on to the memcal. my question is this, i was told that on this car the chip has to be "calibrated" when installed? does anyone know this to be correct, or can i just pop the new one in and erase codes and go. i'm working on this for my mom and she's really at a loss without her car. i know the dealer is gonna beat her up with a bill and she just does'nt have it so if anyone can help me here it would be greatly appreciated- thanks
new memcal, calibration reqiured?
at first there were no codes and had the stalling condition,but would start back up, then it died on her and would not start up till later that day , after we towed it home.thats when we checked codes and got a 42 and 43. so i replaced knock sensor, my dad had bought one already anyway, cleared the codes by disconecting the battery and did the idle relearn procedure. now i only get a code 43, it does not seem to have stall condition but at half throttle or more it misses something awful. sounds kinda like a rev-limiter on a race car if that makes any sense.idles fine and is responsive at the lower rpms. so i dont know what procedure you speak of? .what about the memcal?if i get one from the dealer can i just pop it in and erase the codes, or is there more that needs to be done. i'm all ears, so to speak.
yeah , that's because it's not the ecm. just got back from the dealer and he directed me in the right location. i'm going out now to pull it out. i read in another thread that if the ecm is bad, it wont spit out codes? this one does. i also read gm had alot of problems with ecms in these years. not sure what to do here, what would you do?
me again. just put a new ecm in from autozone, erased codes, did idle relearn and guess what same thing. i'm guessing memcal chip is next and if that does'nt do it i dont know what i'll do. just thinking out loud here, does anyone think the coilpacks could cause this condition?fuel pressere? i tested it with a gauge, had 45 psi when i keyed the ignition and held a steady 40 while running. a short in blinker or ignition?blinker has issuses and you have to jiggle key sometimes to get it to turn? just grasping at straws here. o boy
no what i ment was
go to autozone tell them you scanned for codes and got a 43
then tell them to look up in the computer that they use to find out what part you need and find the info for code 43
then they can print that screen then after they give you the print out get you timing gun and multimter and follow the instructions on itI Like V660s
Does Chevy make beer
~Jayme~
