Here's my story: Not too long ago I bought a DHP Powrtuner from someone with the AVT-838 hardware model. The laptop the DHP powrtuner came with had a crappy battery life and I couldn't use my newer laptop because I didn't have a keyspan adapter. Unfortunately I bought a power inverter not knowing that the OBD2 port and cigarette lighter are tied to the same source or something of the sort. I ended up frying my powrtuner after having it for less than a month.
After doing a lot of research I found out that http://www.avt-hq.com/ manufactures the AVT-841 boards that DHP used in their final years. Since this is the same hardware used for DHP, I'm hoping that someone would know if I could just buy one of these from this website and use it with the DHP software. My main concern would be that the hardware is not compatible because maybe DHP used a custom firmware to make this hardware run with their software. I have no idea if this could be true or not. Does anyone have any way to contact Charles Beyer, the former Programmer/Owner of DHP to find out this information?
