Lumina TBI ī93 3.1l computer
  • Lumina TBI ī93 3.1l computer
    Hi everybody; I donīt have a part or model number but the output transistors are blown. By the numbers on them I canīt find the original? or substitutes.
    It has four with the following:
    44 33 M 324, 50 98 M 324, 8790M 317, 8790 M R004.
    If you need any more info, please let me know
    Suggestions as to info, original or substitutes, where to buy?
    Thanks, from Venezuela.
    What is the service number on the ECM?
      Hi Dave; Service Number 16196391 BJBF. Then comes some bar code and, maybe serial number? 86BJBFKD32220382.
      Itīs all on one sticker; thought the rest might help.Thanks Alberto.
        Not sure how shipping would be but here you go: http://www.ebay.com/itm/1994-1995-LU...item1c1fbe4018
        Getting the components for that ECM is going to be a royal pain, If it's just the injector drivers you could steal them out of another one like a 1227730 but you'd have to do a lot of research to get a good aftermarket replacement transistor for it.
          Hi Dave I know about the royal pain! Now Iīm not a mechanic, just an electronic technician. If anybody knows what type of transistors these are, PNP or NPN, or whatever I wouldnīt mind trying some substitute.
          Went to the ad, but it says they īdonīt ship to Venezuela, canīt understand why?
          If I get this to work, Iīll let you know.
          Off topic, would any of you say itīs safe to buy on eBay even from China? Thanks a lot!
            the injector drivers are FETs, i know that much.
            and i'm not sure how much of this will apply to you application, but
            mentions a few replacement injector driver transistors.
              Thanks Robert but his model is different. It uses Field Effect Transistors, thatīs why the pins are called Gate, Drain and Source, G, D and S in the pic. Mine uses bipolar transistors Base, Collector and Emitter.
              Thanks, anyway.
                Hi guys, this ECM has four drivers. Do they only control the injectors or something else? Thanks.
