Adding fuel to the injector offset vs base pulsewidth took care of the idle hunt in closed loop. I have to investigate to find the next table to adjust to correct the intermittent engine stall when the coolant fan turns on. The USB Extreme ALDL from Moates is necessary to datalog and emulate 8F code mask and it has proven so far a tremendous help in the short time I've been using it.
