This is more a heads up than anything. As far as I can recall, the most in depth guidance I've encountered regarding tuning a fuel injector size change across the forums has been limited to setting a base injector pulse width arrived at by calculation or trial and error for an acceptable idle for a start.
Not much is said about injector offset vs. pump or battery voltage. In my case running 8F with 60 lb/hr injectors about 12 psi above their rating, I believe I have discovered the cause of my persistent rich idle or at least part of the cause.
I also setup a history table in Tunerpro5 to follow pump voltage and have recorded voltage variation in excess of 1 volt and nearly as much as 2.
After looking at the offset table in my tune which for the most part shows values for the stock 23ish lb/hr injectors, I got to searching until I found the spec sheet for my DEKA injectors, noted the differences and realized that this over sight contributes to the difficulty in establishing a stable idle after such a change.
Whenever an accessory is turned on causing a voltage change it might affect the fuel delivery. When the engine/alternator warms up the voltage changes also.
I'll be making one important change for a more stable fuel pump voltage to go along with intended value changes, bypassing the stock pump wiring in favor of a "Hot wire" arrangement with direct battery feed to the relay and then to the pump for better current and voltage delivery.
At the moment I can hear my fuel pump oscillate with the turn signal on. I'll be looking at an alternator replacement also as it seems to drop off on occasion.
I found this link on the forum addressing EGR and fuel delivery that includes the formula for calculating the base pulse constant;
The spec sheets are for the 60 lb/hr injectors I use. Here is the link also;
