Okay, I don't like being told I can't do something. It just makes me find a way, but I need a little skilled help. Hopefully someone knows the answer.
I located the data lines from the PCM to the DLC under the dash.
I plan to capture any 'feed' data I get through the line into a raw binary file.
But how do I command the PCM to feed the data? There has to be some sort of signal that tells the PCM, "Hey, give me what you got!"
I considered using HPTuner to command the read and tap the data lines during but I'm afraid of misc communications corrupting the file.
If anyone has any info please help.
I WILL get the Binary form of the PCM one way or another. I just don't want to hunt down a DHP or hold a GM Tech at gun point, lol (just kidding mr. officermer)
Or is there a way to solder to the ROM and access the memory like it was a HD?
an ELM cable or any other VPW x4 capable setup does the same thing if it doesn't support block-write capabilites.
