What about the cost?
Tuning available for 93-95 L32 and L82 PCMs
95 Camaro, OBD 1.5 PCM 16196397 files for ProTuner
There's hope! I have been searching far and wide for the files to use in ProTuner so that I can figure out what is wrong with my car. Have the documents that you were working on been published any where? My car is a L32 3.4 L v6. I purchased a cable for this application and loaded ProTuner RT. Mark Mansur suggested the $EE files but I haven't had any success. Protuner says it is connected but all of the parameters just roll randomly. Please let me know where to look for your handi-work.Originally posted by robertisaar View Postthe engine side is more or less 100% decoded.
the transmission side is less so, but still highly understood.
the same definition will work on FWD or RWD applications. keep in mind that there are actually 4 versions of the BINs out there though, i've only focused on version 4 since not only is it the latest revision, but it has most, if not all applications covered.
are you running the latest version of TunerPro? 5.00.8075 is the newest version.
is there a log loaded? depending on the speed of your computer, if a log is loaded and a new ADX is selected, it can take some time for TP to redecipher the XDL log. this depends on both the speed of the computer and size of the log.
can you take a screenshot?
The files that I selected for use were removed from TunerPro when I upgraded to the latest version. The file you sent has been loaded now. I found A278.ads for the bin but I am not sure what to use for the xdf. Any suggestions/ recommendations? Sorry, I have never used TP before. Please be patient.
Thanks.
Thanks for your patience and tolerance. Some files exist that look like they may work but, I'm not sure. Is there a web site or someone who sells this stuff? I really need to know I have the correct files. It is still better than buying a Tech 2 scanner. By the way, my car is a manual transmission. Seems like the files for these cars are tougher to find.
Thanks.
Use at own risk.
i've been delaying releasing this so that i can test as much as possible, but i can't test everything...
this XDF works for all Gen 3 P66 V6 BINs. if you open a Gen 0, 1 or 2 BIN, idle and main VE will look VERY odd.... as will other simple things like target idle speed. i'll have to make a list of which ones work and which ones don't... there are 6 total that won't work and 49 that will, so there's a pretty good chance that whatever BIN your PCM is currently running is compatible.
also, there is a complete lack of organization... everything is entered in the exact order that they appear in the BIN.Attached Files
