Nope, its not and it would be well worth it. Use the 3400 injectors, i dont care which kind (i think the newer ones are prone to clogging...but I may be wrong).
The multec 2s are the spawn of satan! I had a hell of a time tuning Nate's car with them. I also had a hard time with John's car.
For some reason they seem to vary from car to car. the code that worked in nate's car seemed to suck in john's car. The 99 3400 does not have the multec 2s, so it probably wont be as bad.
Gor... see if you can get a set of 3400 injectors from a 99 or earlier car. They seem to work better.
Tuning a chip is definitely worth the trouble and money. It made a very noticable difference in Nate's car... both in power and driveability.
One problem you guys might be running into with the Multec II's, is that they were designed to run at a different fuel pressure than the Multec I. If you use them, I suggest that you swap the entire fuel rail (e.g. the fuel pressure regulator being the important part here), and you should see much better results.
Here is some spec info on the Multec II, its a pdf file so you need the adobe reader:
Hmm, I had heard that the 3400s got a higher fuel pressure, but I heard that after 2000 which I believe is multec 2 era. Its good to 72 PSI! Wow, what the heck are the Multec 1s good to?
The fuel rail, lines, etc... off the engine in Gor's car were never removed from the 3400... it was installed as-is right out of the car it came out of..
Ok, here is my setup for my 3400: I have the Injectors from the 3.1, 3400 fuel rail, 3400 fuel pressure regulator. Would that effect the car in any way?
1995 Grand Am GT 3400 V6 / 4T60-E / Engine Swap 3400 Engine Swap Guide Version 2.5 is Available! www.3400swap.com
If the 3400 is a 2000 or newer, I would recommend getting a pre2000 fuel pressure regulator (45PSI)
(junkyard, $5, of for free if you hide it in your pocket )
I found that it ran a bit better, plus fuel mielage went up.
basically if you use the new injectoers (designed for Higher PSI) you have to use the new regulator... If you use the old injectors with the new style regulator or vice versa you will have too much or too little fuel..
