Ok, so a few weeks ago, I turned on the Rendezvous and had the radio playing for the girls while they played outside and I worked. They went back inside, and I thought they had turned it off, as I couldn't hear it anymore. Well, needless to say, when I went to go move it, the radio was in fact still on, but turned down almost all the way. So yep, you guessed ir: dead battery! I thought it might have enough juice in it, so I had tried starting it a couple times, but it didn't catch. So I just hooked the battery charger up, put it on Start, and started it up.
Now, the annoying things... Ever since then, the fuel gauge has been acting funny. It will stay at full until around 200 miles on the OD, then it'll track properly until its empty. Now, if the car sits and idles for a couple minutes, it will drop to empty, and the low fuel light comes on. Drive it for a couple minutes, and it goes back to full.
The other annoying this it seems that sometimes the ABS detects slippage or something, as the brakes seem to be cycling, similar to if the wheels were actually slipping on ice. It doesn't do it all the time, and I haven't really been able to tie it to anything specific. On a few occasions, its been enough to disable the ABS and AWD. At least when that is done, it doesn't happen anymore.
So, do I have issues with the BCM, ABS Module, both? Something different? These are the only issues that have come up, which makes it even more confusing.
