Ok so here is the deal, i have a 1995 beretta (l-body) with an OBD 1.5
I took out the 3100 and put in a 3400 with the following engine mods,
01' LA1, Ported & Polished LIM, LX9 Ported and Polished UIM, L36 Injectors, LX5 65mm Throttle Body, Cold Air Intake, High Flow Cat, FULL 2.5" Exhaust, Highflow Cat, Magnaflow XLTurbo Dual Tip Stainless Muffler, 8.2mm Taylor ThunderVolt Wires, NGK Iridium Plugs, EGR Delete.
So far the computer has done well fixing the fuel ect making it idle and drive nice,
but soon I want to put headers on from WOT-TECH.
I have been told that i will not benefit much from headers unless i tune ect
Is this true?
I know nothing about fuel/tuning,
What are my tuning/fuel options?
Adjustable Fuel pressure regulator?
OBD2 Swap?
Other Options?
I want to know what is easiest and or cheapest
As well as which is safest and most reliable for my engine.
And also which will result in the most power from my engine.
Thanx in advance!
Is this true?
OBD2 Swap?
Other Options?
Thanx in advance!
