ECM - Trouble Code 33
  • ECM - Trouble Code 33
    Hi everyone,
    I have a 91 1227727 ECM (3.1 MPFI) that's giving a Trouble Code 33 which is MAP sensor voltage high. I checked the voltage between the ground and the +5 volt reference signal at the MAP sensor and it's battery voltage (12 volts). Am I right in assuming that the ECM is probably bad? I tried a known good MAP sensor with the same result.
    Thanks for any advice.
    -- Scott
    check for a vacuum leak...
    1990 Grand Prix STE Turbo
