95 cutlass supreme vats delete on ecm
  • #31
    that's for a 94-95 LQ1 car
    that's for a 94-95 3100 W-body
    for the cavy, is the eigth digit of the VIN 4 or F? it seems there were 2 2.2s offered in 2002 and they may have different wiring schematics.
    • #32
      its a vin f car
      • #33
        looks like the cavy does have the equivalent connector of a w-body C100... also named a C100, which is more or less a cabin/underhood connector.
        • #34
          man them diagrams are nice i owe u lol i hate to ask because you been such a great help and took a lot of time to help me but you dont happen to have a pin out of what is what on the bulk head plugs were motor harness bolts to body harness at if not no big deal i make due with what i got but it help me a lot
          but u dont know how thankfull i am of your help your the best man and im gald i join the site and i will donate some money to the site because seens i been asking this site been nothing but 100% help thanks alot
          • #35
            got a picture or drawing of what you mean? AFAIK, the C100 seems to be the major bulkhead connector on the cavaliers as well.
            unless you mean the 95 cutty bulkhead connector?
            • #36
              yea i mean the 95 bulk head harness plug were motor harness bolts to fire wall to the body harness them j body ones are great them will work out great if u had some thing like that on a break down of the c100 i guss thats the plug im talking about for the 95 that would be great and work out nice
              by the way how do u do it
              all these diagrams at the flick of a eye but anyways thanks
              jeff
              • #37
                i grab my diagrams via alldata
                • #38
                  no joke u got this all from alldata mayby i need to look in to alldata lol
                  well thats all going to help me a lot
                  im going to get it runing for now then ill build a harness with a tunable ecm this winter
                  • #39
                    well i got a old jbody harness im going to cut off after the bulk head plug and use to wire to the olds harness should i swap all the wires over or just the main ones i need to start and run motor seens im going after market gauges i plan to start tomorro on this
                    • #40
                      your call. i would rather have everything up and running to make sure it's all functioning.
                      are you going aftermarket tach as well?
                      • #41
                        i guss ill wire them all up then thanks
                        • #42
                          ok i been workining on this harnsess all day lol i hope its rite lol but im kind of stuck i have one big pink ign feed wire to the fuse box on the 95 harness and the cavalier just has about 6 little ign feed wires do i put them all togeather ???
                          • #43
                            i assume you're talking about this circuit?
                            if so, it's more or less the same circuit, ignition feed is ignition feed.
                            • #44
                              yea the cavalier had 6 pink ign wires vs the 95 olds had one main ign pink wire i just put all the pink ign wires togeather
                              • #45
                                well my harness is done i deleted any thang i knew was gone or would not work on the car
                                i wired the ign and all that good stuff to a jbody harness plug sure hope this works if not its going to be the high buck way and buy a 00 trans mission,ecm,and harness
