Hey guys, I was on here a while ago and got the EGR adapter. Finished my 3400 top swap on my 3100 94 oldsmobile cutlass ciera. Ended up also putting in a larger exhaust because it was choking itself. Now with everything else done it still seems like it should have more pep than it does. I'm wondering if the stock tune is holding it back.
I'm pretty sure 96 Ciera's got the OBD II computers, but I'm not sure if everything else on the 3100 SFI engines and 4t60-E transmissions were the same as on the 94's. If they were I would think that maybe I could just put the 96 computer in my 94.
I was wondering though if any of you guys know what's different between the two? Did the 96 ciera's have a MAP instead of a MAF? Basically I'd like to keep the MAF sensor and at the same time have a computer I COULD ACTUALLY TUNE!!! UGH!!! I was reading older posts and I've already contacted TuneCat, but basically I'm tired of having a computer that I can't do anything with.
So can the computer swap be done, maybe with some repinning of harnesses? Or would I have to go through the PITA process of putting a whole engine harness in and messing around with that headache? I was hoping since they did put the OBD II in the 96' Ciera's but they kept the same Engine/Trans combo that I could get away with a somewhat simple swap.
Thanks in advance
Thanks in advance
