With tuning, you shouldn't have a problem with emissions related codes (and I am not talking about turning them off either). Headers won't hurt, but the high flow cat might. Very doubtful on that either but it really depends on what kind of testing they do.
2004 impala 3.4l pcm tuner
You can, either a 62mm or a 65mm, go with the 65mm for your 3400.As of April 2
Engine: 2006 SV6 3500 LX9
Trans: 2002 Getrag F23 5speed
Injectors: #36 GTPs
TB: 65mm TCE
Maf: 1999 3400 Montana.
Beverages: Ice Cold CANADIAN.
Updated 2016-10-22: Getting started / how to threads for using VCM Scanner V3 and newer ----------------------------------------------------------------------- Your Guide to a good tuning experience 32 and 64 bit Windows XP, Vista, 7 8 10 MPVI USB driver installation
There is no pdf or manual for the HPTuner but there are some posts and links that might help.Ben
If you want to learn to tune,first learn to diagnose.
Once you understand the OBDII system and can diagnose it,it'll be alot easier to understand how to tune and modify it.
The most common thing I see with most people getting into tuning is they haven't a clue how to diagnose. Everytime there is a problem they look at the tune.
I would suggest getting into it if your really into cars though,it's fun and you learn a buttload about engine dynamics,combustion,exhaust,intake theory and all sorts of fun stuff like ideal gas law etc..
Just don't expect it to be quick,cheap or easy lol.
