ok, so i have been convinced that the ECM i need to run for my swap is the 7730. the basic research i have done is that it is much faster, more tunable, and flexible than most the other ECM's that i could use. the motor that i am swapping is a bone stock 3.4 out of a 95 firebird. i hope to retain as much of the stock snsors and such as possible. the motor came with them, ran well, and its paid for. it also came with most of the stock harness, so i have the connectors for those sensors as well.
what im wondering is if the 7730 will be compatible with the sensors i have.
also, what all sensors, etc does the 7730 require? im planning on retaining the DIS, so the list of stuff i know i need to retain is: crank sensor and coil packs, TPS, IAC, water temp, IAT, injectors, O2 sensor. any others? emissions arent required.
what should i get a donor harness out of to make this easier?
and does anyone have a list of what all the other service numbers for the 7730 replacements and the applications i can source this from? i havent found anything other than 3.1 camaros.
thanks
Michael
thanks
Michael
