LMFAO, of course jonny, you would start a topic like this.
7730 for use on a geo 3cyl..... READ
ENGINE HAS INTERNAL DAMAGE. THIS MOTOR WILL BE TAKEN OUT OF THE FIERO AND REPAIRED IN TIME. UNTIL THEN, A L67 WILL RESIDE IN ITS PLACE
87 fiero gt 5spd 3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe, 2.5 inch ex, flowtech muff, 7730 ecm, moates.net APU1, self tuning *learning* (GOT FROM MY BROTHER, divorce reasons.)
The '7730 only has one injector driver. It just has two connections at the ECM.
The ECM will "run" a 3 cyl, but the problem is not whether it will run it or not, but what settings to use in the bin, to have a "3 cyl" setting, and the larger problem yet, is what modifications are needed to the MEMCAL itself. There is a hardware side to the cylinder count that needs to be addressed when using the same ECM on an engine with a different cylinder count. I know on one of the other forums I'm on this was being discussed, for a different 3 cyl project, but not sure how far they got with it.
I wouldn't try to run DIS on this engine, I would use the dizzy and adapt an HEI computer conrtolled module to it, if it doesn't already have a compatible ICM.
