So I've been having what I thought was a ground issue. I tried to re-pin my grounds with a wire that I ran as a ground. I was popping pins out, and replacing them with the ground wire I ran.
Well, I got careless and accidentally put the ground to pin D13 in the ECM. That's the reference voltage to the DIS module.
I figure I popped the ECM.
What I've tried:
I got another ECM from the junk yard, no improvement. (I can't guarantee this one was good though)
Replaced the CPS no change.
What I've got.
1.) I've got spark. When cranking it is firing.
2.) It smells like I've got fuel, but it's not very strong.
What I don't have.
1.) In tunerpro the aldl data stream shows the engine RPM as 0 even during cranking.
According to the manual, I've tried trouble shooting a couple things, and it seems to point toward a bad ECM.
Does anyone have any ideas what else it could be? I can't make it to the junk yard for 2 weeks, so getting another ECM is going to be tough. I have a spare set of coils/icm that I could swap in, but it's a severe pain in my ass.
I don't see why it would be the coil pack since I grounded the ECM where it shouldn't have been, and the coil was essentially unplugged.
Does anyone have any ideas?
What I've tried:
What I've got.
What I don't have.
