I noticed GM switched to a non engine vacuum sensitive regulator placed in the tank unless I missed something, otherwise after some reading up on tuning for use of larger injectors I found a discussion about how the variable pressure regulator due to vacuum and boost exponentially affects the larger injectors fuel flow when compared to a regulator not receiving input from anything other than atmospheric pressure, calling for more drastic changes in the fuel table as rpm and boost levels climb.
After giving it some thought without pulling out formulas, It seems that an open atmosphere regulator would make more sense considering the pressure would vary with sea level reducing pressure as altitude climbs and visa-versa.
It also stands to reason that it would make for a more linear fuel flow by providing a constant fuel pressure which should result in a more uniform change in fuel delivery where a 15% fuel flow increase in the base pulse constant at idle is effectively 15% increase everywhere on the fuel map instead of progressively more due to increasing fuel pressure.
I've noted the complaints about how hard it is to tune for larger injectors and am considering not connecting my regulator to the manifold in order to maintain a constant fuel pressure of about 60-65 psi for fuel atomization benefits provided the 60 lb/hr/43 psi injectors can be pulsed low enough for idle fuel needs. They are rated for up to about 85 psi pressure and I'll be using two pumps.
I'd appreciate any input from someone who has information that I should consider as to possible adverse consequences.
