I may have asked in the wrong section (Introduction9 so will try again.
2.8 or 3.1 V6 engine. fitted in a lamborghini replica.
OK, after pulling more wires out which were apparently open ended codes 54 and 43 have mysteriously gone, I am now stuck with a code 42. Can anybody explain what the ECU might be telling me (42 - The EST signal did not change when the ECM applied bypass voltage to the ignition module) and what the possible causes are? Checked signals with scope and digital pulses equivalent to 6 cylinders firing in 2 revolutions is normal, CKP signal also normal, inductive pulse, every 6th pulse is a double one.
Thanks guys.
Pinout of this car as it stands today attached to my last post in introduction.
Thanks guys.
