3500 fiero aldl help
  • 3500 fiero aldl help
    cable works now, but its not logging the data.
    this is with tunerpro rt. the error count is counting like everything is an error! i took a pic to show what i mean.
    any one know whats going on?
    why isnt it showing any data?
    2012 Chevy Sonic Turbo 6spd
    You clicked "Send Command", then "connect" right?
      Try this def (the IAT/MAT should be correct on this one since the original had the tables inverted) http://isaachayes.60degreev6.com/ald...730-a1-MAT.ads
      See if it's any different. If you saved a log you can load this def and hit play back and if it's the right def for your code mask (if it is truly $A1) it will display the playback correctly.
        If that dosen't work i'll send you mine...
        *edit, i tested that one and it works with my .adl
          shit, forgot to look at this today.....
          send command, then connect?? ok ill do that
          whats up with my def? are saying my def is incorrect and that i may have actually recorded info, but cannot read it because of the incorrect def?
          i recived the def from darth, he wrote this chip.
          he belives that its a problem with windows vista and not with anything else. perhaps not?
            what's this about "send command" then connect?
            I just hit the Connect/Disconnect ALDL button and it always works fine. Did darth do the chip in $A1 code? If not then i have one that is...
              yup, its all in $a1
                LOL Dave that's the one I modified and gave to you so you could read the IAT correctly remember?
                If you wanna try ScannerPro I have a def for that in $A1 code. No CSV export but you can play back everything. www.scannerpro.net
                Here is my $A1 def for Scanner Pro.
                  i am merlot566jka's brother, and i have this project now. turnerpro was doing the same thing with my xp carputer.
                  ENGINE HAS INTERNAL DAMAGE. THIS MOTOR WILL BE TAKEN OUT OF THE FIERO AND REPAIRED IN TIME. UNTIL THEN, A L67 WILL RESIDE IN ITS PLACE
                  87 fiero gt 5spd 3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe, 2.5 inch ex, flowtech muff, 7730 ecm, moates.net APU1, self tuning *learning* (GOT FROM MY BROTHER, divorce reasons.)
                    i got it to work. i needed to use the 730_v6_a1.ads file from moates web page. that got it to start displaying data for darth to use.
