Ok, so the plan with the swap was to keep it simple harness wise and use a 7730 spliced into my Fiero, run a 3.1L code, datalog it, and tune the tables/maps to run the LX9s (3500) needs. Merlott is currently running this to my knowledge and it worked until he had mechanical failure.
But recently I spoke to another Fiero owner who said he is running his 3400 swap on a camarobird OBD 1.5 ECU because it has provisions for his SFI/DIS crank trigger as well as knock and various other sensor inputs and said it runs beautifully and that it was very "plug and play".
Looking at the 7730 I will need a external trigger/sensor and lots of tuning to begin with, I can only wish I was attempting something more "plug and play".
To my knowledge the 3500 crank trigger is a different style than the 3400/3.4 anyways (if the 3400/3.4 are the same to begin with), and I'd need an external trigger either way? But still, which ECU would make this LESS of a pain in my neck, this is my first swap and I'm SWAMPED.
I thought OBD 1.5 was very UGLY to tune?? Is it a better option for me?
Tuning gods?
Help?
Tuning gods?
Help?
![confused](https://www.60degreev6.com/vb5/core/images/smilies/confused.gif)
