Ok I got my definition file, and it shows up ALL the data for everything under the sun. I'm using TunerPro RT
1) BUT when I go to log it, and view it, it's missing BLM's, O2, etc etc. All the important stuff I wanted to log.... What gives?
2) When I click play back, it doesn't work. It does something but none of the values change, except the trouble codes, they all randomly go from OFF/ON
3) Is it normal to have a few knock counts when starting the motor? That's when they show up.
Below is a csv example... HELP!
Missing info (aside from screwed up playback) :
BLM
INT
Oxygen mV
TCC Slippage
IAC Steps
Voltage at Fuel Pump
Spark Advance shows up but as a weird #...
All above values work fine in real time though..
BLM
INT
Oxygen mV
TCC Slippage
IAC Steps
