Does the factory chip from gm have a fuel cut feature if boosting more then factory specs? if so, can someone here explain what happens? Does it cut the fuel essentially shutting the car down till you lift off the gas?
This isn't on a TGP car, I am just running a boosted 3.4 in my fiero and using the stock computer with a aftermarket chip Mask $24 designed to handle boost so the timing and fuel tables have been set up for boost.
It seems on my setup anything over 11-12 ish psi the car cuts out. I beleive its a fuel cut issue because the car falls on its face, and won't refire till I let off the gas. No matter what I set my plug gap to, the same problem happens every time, right around 4200 rpm or so in 4th gear, and even in third sometimes with enough load on the motor but at the same rpm.
has anyone dissected the $24 or $24a mask and can tell me if my suspicions are correct and if there is a way around this problem? I want to run 14+ psi and this problem is standing in my way.
