3500 injectors
  • 3500 injectors
    I know the plug is different from the earlier injectors, but are they the same impedence? I would like to make an adapter plug for them to work on my hybrid, but didn't have my meter at the shop today to test.
    Yup, same resistance as the other stock 60V6 injectors.
      Thanks. So my harness adapter should be an easy deal, then.
        What are you doing, adapting the 3500 injector harness to something else? That is what I have to do once I get my wiring harness.
          Yes. I want to make a pigtail basically. Actually, then I would have to find a bunch of chassis-side connectors from 3500's. Probably just re-pin the stock conncetors from a Gen1. This way the rail will plug in like it would stock.
          Do you know what pressure and lbs they were rated?
            24# @ 55psi is what I have read. Maybe be in the delphi site but I didn't look.
