I'd Love To Be Able To Mess With Fuel Tables. I Get 28 MPG HWy Now, But 30 Or Better Would Be Cool. My Car Runs A Tad Rich. I Dyno'd it back in april and the afr readings were rich. low 11's i believe. I've Got A FWI And No Cat. All Sensors Have Been Replaced, So I'd Love To Tune It.
1994-1995 OBD1.5 Reflashing...
Pics and files are now up at my site here:
Pics of the ALDL interface. If you want to scan the 94-95 3100 (except a bodies) check out the def files there. Read the text files that go with them. The tunerpro RT one works great and I've added/fixed some things over the version you get at the tunerpro website.
The scanerpro one is not finished, and not tested in it's lat revision. Of course scanerpro is still in beta, but having GUI gauges with logging and play back is too fun not to mess with!sigpicNew 2010 project (click image)
I would like to bring this back up. Maybe talking to the companies again would be worth a shot? I have an extra 3100 ECM that Id be willing to let someone try and re-flash for the specs on my new motor if anyone has the ablity to.sigpic
3400/Getrag 284 5spd
350/NV3500 5spd
2014 Chevrolet Malibu LS
That's the problem. The guys that would don't have the info on where the tables/whatever are in the program to hack it, and the guys that could dig into it, are too busy with cracking 2008 cars to bother with old cars. But feel free to try what I did and see what they say.sigpicNew 2010 project (click image)
Hi all, From what I read there might be alittle hope for OBD1.5 ? I'm still not sure thats what I have,but I assume from everything I read it is what I have,and that sucks.. My ecm I believe is a 16155162 Rev D/F ? Theres something on the inside about CAV 10 as well? I have a 12 pin connector under the dash,that only has 3 actual connections in it..
Now the 89'Buick regal with a 2.8 mpfi has 4 actual connections in its plug (same plug) The scanner tool uses the same hook up and reads codes on both of them,the Grand Prix being a 95'..
Exactly how hard would it be to convert to Obd1 ?
ObdII I know theres alot involved,But now would be the time,seeing how my engine bay is still gutted..
Russ
IsaacHayes, is this an option for our OBD1.5?
For other 94-95 engines just look to see if it's under vehicles supported on the TunerCAT page and purchace that particular definition file. Check to make sure it uses the 27X512 prom too. (It will say it to the right of the definition file)
Then start tuning. (You have to figure out what your doing first however)
Now if you want to tune on the fly, (Change parameters while you are driving), you can do that as well.
Instead of a chip burner, you'll need an Ostrich Emulator:
The newest breed of emulator has evolved! This is the newest Ostrich, the 2.0 unit. It is extremely small and compact, durable, versatile, and powerful. Full 921.6k speed, from 4k (2732A) up to 512k (4mbit 29F040) and everything in between (27C128, 27C256, 27C512).
And TunerCAT RT Tuner.
You'll still need the chip adapter first mentioned, a stock bin somehow (I may be able to get a hold of one but I think gmtuners has them somewhere on thier web site), and the correct definition file.sigpic
350/NV3500 5spd
That talks of removable PROM based, which our ECM's are not. They are flash based. You don't use a chip burner with ours. It would be flashed through the ALDL cable like OBD2.
TunerCat supports $1FA which is 94-95 L82 3100 removable PROM ECM found only in the A bodies with the funky TB with MAF built in, and no MAP! You could use a normal MAF 96+ and swap all that stuff over from the A body possibly, but probably OBD2 swap would be easier with a 96 car of your model.
You should try emailing tunercat and seeing if they could add our ECM support to WinFlash, or make a version of it for our ECM.
Winflash is made for the LT1 engines 94-95 which have a FLASH based ECM like ours. That is the only product they have that is closest to working with our ECM.
EDIT: the lastest TUNER software they offer has the WINFLASH stuff built in if you use the $EE definition...sigpicNew 2010 project (click image)
I gave up hope a long time ago and performed a OBDII swap on my daily driver... I'm glad I did. I never would have turned a 14.8 with my hybrid motor if I didnt. And now I already own everything to tune the pink project.
How does this work?
I'm just curious as to how this Ostrich thing works. It's all greek to me
http://www.moates.net/product_info.p...roducts_id=1691995 "Driftwood Metallic" Cutlass Ciera
Mods: K&N airfilter, Addco Front & Rear Swaybars, 2.5" cat-back exhaust w/ Hooker Aerochamber muffler.
Down the road: Cam(?), 3400 ported UIM & LIM, ported heads.
It takes the place of the chip that you reprogram in your MEMCAL. The reason behind it is so you don't have to pull out the MEMCAL to write new information to the chip all the time, and you can write the new info to the Ostrich while the car is running.-60v6's 2nd Jon M.
Ah, so in my retard terms, it's kind of like using one of those hypertech programmable tuners but much more efficient, right?
Does playing around with this system on an OBD 1.5 take a lot of mechanical/computer skill or is this something that even myself could read up on and start messing with?1995 "Driftwood Metallic" Cutlass Ciera
OBD1.5 doesn't use a chip, its flash based and no one supports it.
I think you have the a-body with the weird TB/MAF setup on your 3100 and you have a removeable chip. www.tunercat.com supports your ecm.sigpicNew 2010 project (click image)
Yeah, it's that odd-ball one Isaac. One of the reasons that I haven't tried to tackle the 3400 upper and lower intake yet. I may just decide to buy them and take them to my mechanics and say "here, put these on." I know it would cost more, but I'm afraid to F---something up. If I leaved closer, I would probably just ask someone that Ben knows to put them on and have it tuned, but alas, I live in PA.
Thanks again, IsaacHayes. Have you had an experience with them yourself?Last edited by 1995 Gold Ciera; 09-07-2008, 07:22 PM.1995 "Driftwood Metallic" Cutlass Ciera
