Struggling to get the 3900 started. I need to confirm I have the plug wires connected properly starting from the dual plug end of the ignition module. It shouldn't matter what position they are in on the same coil since the plugs fire in pairs. Please be specific because it's not in the standard vehicle.
My problem so far is a crank without run. I was able to get it to run twice briefly using starter fluid which indicates to me that it's not getting enough fuel. It ran erratically though. I'm not going to use the starter fluid again because I know it's dangerous and I did get a reversion. My pump is working, I have power to the injectors and obviously I have spark so the problem appears to be between fuel quantity and possible timing inaccuracy due to a sensor being out of wack and causing a problem.
