I have the Moates APU1 emulator with TunerProRT and I have not been successful getting it to connect through the ALDL connection to view sensor readings to make sure the car is wired properly (3900 in a Fiero). The help section doesn't help much with atypical setups, I'm using the 730 ecm with 8F bin file but have no idea of what XDF file or ADS file to use with this comboination in order to interface properly. I'm trying to connect so that I can test the wiring for my 3900 swap.
The instructions mention the switches on the back of the emulator and a 10 ohm and open setting depending on your ecm but does not state which ecm's require the 10 ohm setting when datalogging.
