I've heard of some using the 730 ECM to run a turbocharged application.
In the process of trying to do a bench test of the 730 ECM using the Turbo Grand Prix binary, so that I could connect to the ECM with my Moates APU-1 I noticed that each plug on the 727 ECM has about 22 terminals resulting in a total of more terminals than the 730 ECM and I can't match all of the terminals between the two ECMs for properly connecting power and input for the sensors.
The bench setup is to make sure I connect everything properly by seeing a signal from each sensor in TunerPro when it is connected.
