what are some companies that sell good wideband o2 kits for a good idea of what my car is acutally doing, so i can better tune my ga. i just got my dhp powrtuner and want to make sure that when i start tuning, i get it done good enough the first time that i dont have to start over from scratch
Good Wideband o2
i have an innovate xd-1 wideband kit. it comes with the gauge, controller and sensor. its a fully programable wideband setup, and you can change things to best suit your needs. it has a 0-1 volt output so you can run the wideband in place of your stock sensor and feed the comuter with it.
aem also make s a half decent wideband.
well i have another bung welded in for the wideband and i think i would tie it in to the dhp tuner with the analog to digital upgraded harness, so idk if that would make the other stuff obsolete or not, but i guess its worth a shot. does innovate sell them direct or do i have to go through somewhere else(third party)
I had a innovate lc-1. had a bit of trouble getting it to work
then I got 2 datalogs out of it, and the next day it was dead. I got a replacement and had no luck with that one either. ended up selling it
considering the high end stuff innovate makes idk if I just had back luck, or if the lc1 is junk
my next WB will be this:
'94 Cavalier Z24 3400 Turbo 5 spd
I'm running both the AEM gauge type and the AEM wideband controller (no display- running with an EMS).
The Innovate LM-1 is great for multiple cars or for a tuner.
325 whp 350 lb-ft
