FREE 3.4 DOHC & 4t60-e trans in Albany, NY
  • FREE 3.4 DOHC & 4t60-e trans in Albany, NY
    Edit: The block and trans went in the trash.. no one wants them, so here is what I'm parting out. I'm not here to negotiate or make a living, so just name a reasonable price for what you want.
    NO international shipping.
    All from a '95 GTP with 92k unless otherwise noted.
    Last updated: 10/15. Parts removed (trans and block w/heads and cam carriers went in the trash). Parts added-
    * Complete Wire Harness
    * ECM
    * Cam Gears (bolts included).
    * Tensioner (actuator) pullies for timing belt (bolts included).
    * Idler pullies for timing belt (bolts included).
    * Timing belt (mileage unknown- not the original. Looks GREAT).
    * Timing belt inspection cover (both of them).
    * Cam Cover.
    * Trans differential
    * Trans differential cover
    * Torque converter
    * Starter. Complete. (near new, a thousand miles if that).
    * Starter solenoid only. (zero miles. installed than removed).
    * Valve Covers (both of them)
    * 7mm ignition wire set (mileage unknown, but they are not the original wires).
    * Rear exhaust manifold.
    * Front exhaust manifold heat shield.
    * Cross over pipe.
    * Coil Packs.
    * Coil pack bracket.
    * Ignition Control Module.
    * Gutted Air box.
    * IAT sensor.
    * MAF sensor.
    * Intake tubing.
    * Cruise control module with cable.
    * Alternator (mileage unknown- not the original. App 20K? Tests good)
    * AC Compressor.
    * Fuel rails.
    * Fuel Injectors.
    * Fuel Pressure Regulator.
    * Fuel Pump (mileage unknown-not the original. App 20k? No noise. ran fine).
    * VSS [Sensor].
    * Other misc sensors.
    * Other misc vacuum lines.
    * Coolant lines.
    * Transmission dipstick tube.
    * Transmission dipstick.
    * Engine oil dipstick.
    * Front knock sensor.
    * Rear knock sensor.
    * Lower Engine mounts.
    * Transmission mount.
    * Trans-to-black bracket.
    * Misc bolts (trans to block, exh. mani studs, etc...)
    * Flex plate
    - Front exhaust manifold. sale pending
    - Rear exhaust manifold heat shield. sale pending
    If there is anything you don't see, let me know and I'll see if I have it. Pictures available of any item upon request. Shipping is done by UPS ground and a tracking number will be sent to you.
    This stuff is off the car and ready to ship the day after payment is received unless I advise otherwise before the transaction is complete. Paypal is accepted.
    The list will be updated if there is more and as this stuff goes.
    Originally posted by MADF1 View Post
    That's right. FREE.
    The engine has 92k from a '95 GTP and either bad rings or a bent valve. It does not have consistent compression. Beyond that, when I ran it, it was great.
    The trans is perfect with about 70k.
    If I cannot get this picked up for free, I will part it out, so if you want parts, let me know and make an offer on them.
    Engine harness & ECM are for sale separately.
    The engine is missing: upper & lower intake and belt tensioner. I started to part it out, then stopped.
    Let me know... I need this gone and it might just have to go in the trash in the next day or so.
    Is the tranny still in the car??
      Tranny is out of the car.
      I will be unbolting it from the block tonight. Let me know, otherwise, it's gone by Monday : )
        I can't get the support from here to pick-up the tranny. If I wasn't recovering from knee surgery I would get it myself. Thanks anyway.
          I don't understand. What's more important, the car or your health? Sheesh.
          Ok, I think I will actually hang onto the tranny anyway. Thanks for getting back to me and hope you get better : )
