3500 Sfi For Sale(350.00)
  • FNJ26
    replied
    goooooood!cause none of you know anything!first of all the cam isnt the same for the simple fact that the 3100 and the 3400 have a hollow cam which was a problem with them breaking.gm corrected that problem with the 3500.look at the diffrence in torque between the 2.i guess that doesnt count for nothing either?
    replied
    I wouldn't call it a 30hp gain. More like a 16hp gain. Why? The 2005 3400 was available in several body styles, ranging from 170hp to 185hp. And they all used the same parts. So how can you have that much difference with the same parts?! Alot has to do with the exhaust and tuning. Since the 3500 has a much better exhaust setup (the manifold design and the fact that they dump individually and don't join until under the car), I would say there is a good chance there was a significant gain there.
    And as far as having a block in front of me to look at, like I mentioned before, I do... I also have 2 3100 blocks right next to it to compare, and I can tell you right now that the differences are not significant enough for a 30hp (or even 16hp) gain from just the block.
  • Syn
    replied
    dang i learned alot of info from this thread, lol
    so now i need a 3500 block since thats where the power is made,
    bahh my hybrid is going on ebay LMAO
    replied
    Care to show some proof that the top end is not where the power gain is? I got proof it is. Ill prove it with this engine im building right now.
    Ill post the stock flow numbers once I have my flowbench testing complete. Best of luck on ebay.
  • birdman
    replied
    I dont think so... man afteer my turrobs be spoolin up i be dustin on dem 3500's dawg werd???? LOL......wow.
  • FallenZ24
    replied
    Dude, you need to just stop while your only a little behind. You dont' know what you're talking about and noone wants to buy you overpriced shit.
  • FNJ26
    replied
    you do that and by the time you develop power ill be through the traps!
  • birdman
    replied
    ummmm. that made no sence....... kinda like most of this thread
  • FNJ26
    replied
    you do that,and by the time you get going ill be through the traps!
  • birdman
    replied
    ok, well then how'd gm up the horsepower in the 3.1 from 140 to 160-165 in the 3100???? musta been the displacement gain.. o ..... wait....... there wasnt one, hmmmm....... and if were gonna go that far, how did the 3.4 tdc get more hp than the 3.1 or 3400 when there almost identical blocks???
  • patgizz
    replied
    ok we're all dumb you obviously know what you're talking about.
  • FNJ26
    replied
    no you are mistaken.they didnt get a 30 horsepower gain from the heads.i have a set of 3500 heads and there not big enough to get that gain.so on that note if you had a 3500 block on the floor and a 3400 piston you would see where the 30 horses are coming from.
  • patgizz
    replied
    was speaking in general terms
  • onefastV6
    replied
    Originally posted by FNJ26
    First Of All The Block Is Where The Power Is. Its Easier To Cut The Heads Open From A 3400 Then Bore The Block.also The Lower Intakes Are The Same.you Cant Use The Plenum Unless You Fit A Throttle Body To It That Uses A Cable(witch Ive Already Done).so If You Put It In That Category Then That Explains Why Your 3.4 Dohc Stick Is Still In The 15's.
    Sorry, but you are mistaken. The block is not where the power is hince only .1L more displacement over older 3400 engine. Now where the 3500 engine picks up it's is in the redesigned heads and manifolds, and tuning.
    I have the complete 3500 top end along with headers on my 3400 block, and have done alot of research and testing with Ben (sappyse107). It will cost alot more to get the 3400 heads to flow more than stock 3500 heads, and the end results will be similar.
    Originally posted by patgizz
    the .1 liter of increased displacement is NOT where the power is. it's all in the cam and top end.
    with that attitude, you won't be around very long, talking to the guy that runs the show like that.
    Pat, the 3500 cam is the same as the 3400 cam.
    replied
    Tell me again what my car has to do with your engines? Ill pay 200 more for a complete 3500. 350 for a block no one here can use without modifications is pretty funny.
