Wanted fabricator/machinist
  • Wanted fabricator/machinist
    i am looking for a fabricator/machinist or perhaps somebody knows somebody.
    need one to make a bolt-on idler pulley kit to replace the a/c compressor for my 3.4 dohc. as far as material are concerned i prefer 6061 aluminum.
    as far as time id like the contract to be completed within a month and a 1/2 which i think is plenty.
    RE: Wanted fabricator/machinist
    How far away are you looking? I know a decent place here in Wisconsin, but that may be too far for you.
      well over the mail is definately an option
        Why dont you take a factory A/C comp. Remove the clutch plate. Then gut the inside of the comp. Leaving you an aluminum shell with an idler pully on it.
        1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
        1972 3/4 ton 4X4 longbed, built 350, 400 auto, 6\" spring lift, 35\" AT/BFG\'s, dana 60 front axle, 14 bolt gm w/detroit locker 4.56 gears. My ricer smasher
