a little background first. I bought curtis walker's old iron head turbo setup from his cavalier many years ago. I installed this in a fiero. it fit, I just had to trim the decklid hinge a bit to clear the exhaust housing of the turbo.
anyways, I sold that setup years ago, and built a new setup based off the same rough dimensions. I have the tgp manifolds, and a new full stainless crossover that puts the turbo in the same position as the old curtis setup in his cavalier. there are a few small differences as the new setup sits about 1/2 inch higher than the older one. Also it uses a vband mounting flange, and is a one piece crossover
here is curtis' old setup
http://www.shaun.saturnet.net./pics/...s/100_0056.JPG
http://www.shaun.saturnet.net./pics/...s/100_0057.JPG
Here is the new crossover
lmk if pics don't work.
this was built for a fiero but I figure it might fit on a cavalier since its modeled after Curtis' old setup. obviously I can't be 100% sure it will fit. obviously some things might have to be relocated like the battery for one.
manifolds and crossover have been heat coated. I also heat wrapped the crossover. will come with Tial MVS 38mm wastegate with a 4 psi spring. I am keeping my other springs.
asking $1200. With turbo will be $2200. Turbo is a billet 6765e precision with vband .82 exh housing.. all parts are in excellent condition.
