Z24 manual trans 1993
  • Z24 manual trans 1993
    Have the 282 from my z24 in the garage its 93 so internal slave had to cut the line near the clutch master so it'll need something worked out unless you just get a new slave. DIRTY but will clean it up no shifter the clutch was going out so pulled it and saved ithe trans. scrapping the car since it was a piece. Can text pics. 616 26$ 11&8 figure the numbers for the symbols above. Asking 100 17xxxx miles. located in grand rapids mi
    Also check and the slave is still good but will need a new clutch line basically get a new master cylinder and do a braded line and your set.
