3.4 DOHC 5 speed ECM and Harness
  • For Sale : 3.4 DOHC 5 speed ECM and Harness
    found a 5 speed DOHC 3.4 in the yard. pulled the ECM and Harness. I know that if your doing a 5 speed swap, it helps to start with a true 5 speed harness. Only issue is that I had to cut the injector harness to remove it, for some reason it was wedged between the intake and lift bracket.
    Simple fix. splice/solder up about 10 wires or so.
    $150 plus shipping
