Wtb tce drtc!
  • I wish there was something to say about this other than I'm completely pissed off at the lack of communication on TCE's side of this. No update in over 2 months when he said he was close to a resolution is ridiculous...
    • My motor is sealed up with fresh gaskets. Luckily the spare crank I had hasnt been modified yet.
      • Modified or not it still works, it would just be cost of the work you would be out on... I'm running the modded crank in mine right now with a factory chain. If done right it only adds chain clearance and doesn't modify where the sprocket runs.
        • Yes, would have been out on gaskets, bearings, and then machine $ not even factoring in my labor.
          • how so on bearings? Currently I'm out the machine work on the crank since what was done is useless and I'm out the money on the DRTC's themselves... As stated all I did was pull the timing cover, remove the DRTC and put on a OEM set. Done, the modded crank is still in there.
            • I'd feel more comfortable using new bearings on a crank going in a different block.
              • I guess I'm confused on how far along you were with this swap... I'm guessing the crank and bearings in your motor were already broken in and you were planning on swapping the crank out for the modded one which in turn would have necessitated new bearings...
                I pulled the current crank got it modded and slapped it back in, didn't change the bearings at all so that's why i was only out gaskets and time to swap the original timing set back in after the failure.
                • Wish I could have just done that. Whatcha gonna do
                  • Guess it is a good thing I was holding off my build til late this year.
                    400whp 435wtq - MMS Race Block w/ 8.5:1 comp ratio, and Eagle H-beam rods. MMS Stage 2 package including Stage 2 3400 heads, Stage 2 Turbo Cam, chromemoly pushrods, and GM gaskets. MMS 65 mm Turbo Kit w 60lb/hr injectors, Walbro fuel pump, and powdercoated intake plumbing. MMS 3.29 4t65eHD conversion, 3500 stall TC. Milzy headers w/ downpipe, magnaflow exhaust, FFP Pulley, f/r strut braces, Msd 8.5 SC wires, Optima Battery, *** bodykit, Bilstein Coilovers. 17x8 AE 185s. Pioneer HU, B/A speakers.
                    • i have not gotten said email.
                      • Originally posted by bob442 View Post
                        Were you part of the last group buy?
                        • on the note of oiling issues, it might not be a terrible idea to drill(and debur) a couple of small oil holes in the camshaft retainer plate so that there is plenty of oil flow to the back of the cam gear where the oil slots can sling it to the chain. when my car is in my hands again, i plan to do just that.
                          • Originally posted by ericjon262 View Post
                            It already has 6 holes...
                            • Originally posted by 3400-95-Modified View Post
                              [ATTACH=CONFIG]7828[/ATTACH]
                              whoops! been a while since I looked at mine, I didn't remember any holes.
                                i'm the "replaced my chain twice and top end once" group....
