Wtb tce drtc!
  • I wonder how many sets he's received back so far.
    • Mine has been shipped usps. So that's two sets from me.
      • Hope he or someone is around to sign for my package.
        • I bought one awhile back new off MMS. I should really send mine up there or hand deliver it to him (since I'm not to far away) and get mine situated as well, I'm not exactly sure if there is something wrong, but I rather have it inspected then wing it once I have the new motor ready...
          2001 GLS 3400. F40 6 speed.
          Mods: F40 6 speed swap. Pacesetter Headers. Flowmaster Muffler. Cold Air Intake. MMS Engine/Trans Mounts. MMS Stainless Allen Header Bolts. MMS Header Gaskets. MMS PP UIM/LIM. MMS No Cat DP. Prosport Gauges. AEM A/F wideband. 8000K HID's. LED Fog Lights. 18" MSR wheels. Nitto Tires. Lowered. Baer Brakes. SC/T Spoiler. Sparco Racing seats. Harness Bar w/ 4 pt harness. A/C Delete.
          • If it has TCE engraved on it then it should be fine, if it's a blank face cam gear then it probably came from this batch, as far as we know only this batch is affected.
            • Wondering if he has received my sets?
              • I don't think anyone has received any update from him. Things may be busy for him with his recent health issues... Hopefully we get some info sometime soon.
                • Any update or has anyone talked to Marc ?
                  • Originally posted by unchained01 View Post
                    No clue, I haven't heard anything...
                    • I tried to contact him to see if it was too late to send mine as I just pulled it out last weekend and got no answer either.
                      1993 Chevrolet Cavalier Z24
                      3400 Turbocharged Intercooled
                      MS3 v3.57+MS3X
                      • I would think its never too late to send it to him, something is up with them and there is no idea how many are affected so it would be very wise to send it in... I just hope he's well enough to get these taken care of.
                        • Originally posted by 3400-95-Modified View Post
                          x2
                            I ordered an external crank trigger off of BritishCarConversions on August 21st and sent him an email when it would be shipped. I have yet to have a reply. I guess we all have no choice but to be patient. He's dealing with a lot of things right now.
                            2000 Silvermist GL2 Sedan w/ LX9 3500 V6
                            Current performance mods: TCE 65mm throttle body, ported 3400 upper intake manifold, ported 3500 lower intake manifold and heads, WOT-Tech Strip performance cam 276/264 adv duration .536"/.520" lift , COMP Cams 26915 Valve Springs, 28# Trailblazer Injectors, TOG headers, LS1 MAF, MMS Walbro 255 LPH Fuel Pump, Custom PCM tune and 4th Gen Camaro front calipers
                            • It'd be nice to hear an update from whoever that he has received them and the issue is being resolved. If something is going on with him, then I wish him the best.
                              400whp 435wtq - MMS Race Block w/ 8.5:1 comp ratio, and Eagle H-beam rods. MMS Stage 2 package including Stage 2 3400 heads, Stage 2 Turbo Cam, chromemoly pushrods, and GM gaskets. MMS 65 mm Turbo Kit w 60lb/hr injectors, Walbro fuel pump, and powdercoated intake plumbing. MMS 3.29 4t65eHD conversion, 3500 stall TC. Milzy headers w/ downpipe, magnaflow exhaust, FFP Pulley, f/r strut braces, Msd 8.5 SC wires, Optima Battery, *** bodykit, Bilstein Coilovers. 17x8 AE 185s. Pioneer HU, B/A speakers.
                              • I just shipped mine back today. Marc gave me a bit of an update at the same time, I hope he don't mind me posting it here to keep people updated with progress
                                "So far I have found two upper sprockets that are out of tolerance but .002" and the gear cutter said that really should not have an effect given the chain length and diameter of the sprocket. The funny thing is, the two Jon (3400modified) sent back were well within tolerance. The problem appears, at this point, to be the lack of oil grooves in the back of the sprocket causing the chain to run dry and wear prematurely. You can see heat marks (blue) on the back side of the one Jon had in his engine. This shows there was a lack of oil getting to the back side of the sprocket which also slings out on the chain."
                                MS3 v3.57+MS3X
