3500 LX9 Performance + Swap Parts
  • 3500 LX9 Performance + Swap Parts
    Everything sold, thanks everyone!
    Interested in the UIM, throttle body adapter and header flanges + tool.
    Can you post more pictures of the UIM?
      Sure thing, I'll take some more this afternoon when I get home and put them up.
      It has been sitting in the same box that I received it in from WOT 3 years ago, so it should be basically pristine.
      I'll get all angles and such later on tonight.
        Added pics of UIM & LIM.
          Is the UIM bell mouthed or just gasket matched? I can't really tell in the pictures. Also, is the external crank trigger the adjustable style or not?
            I'm honestly not sure at this point and will need to get this verified from WOT.
            The external crank trigger is the adjustable style.
              Put me second in line for the header flanges and shaping tool. PayPal ready
                Waiting on a response, will let you know.
                  Porting info requested about the "stage" on the UIM and LIM, sorry for not knowing this originally. I do have someone interested in both as of right now.
                  (sorry for directly quoting you Ben...=P)
                  "The comp 3500 set would be level 4 upper and lower. Hope that helps
                  Sportsman was the gasket match and blend a couple inches in.
                  Ben Phelps
                  WOT-Tech"
                    External crank trigger and TB adapter sold, more parts to add soon.
                      Added:
                      Camshaft 3015/3013 106 ICL 110 LSA - $250
                      Comp Locks and Retainers - $70
                      Double Roller Timing Chain Set - $200
                      New Set of Roller Lifters (OEM) + TCE Upgraded Springs - $130
                      ARP Flywheel Bolts - $30
                        What kind of springs are they?
                        '86 Fiero, 3500, 4-speed
                          These - http://wot-tech.com/shop/gm-60v6/pac.../prod_223.html
                            how are PAC valve springs a upgrade on the lifters, im lil confused as their is upgraded springs for lifter that comes from ls lifters
                              PM sent!
