Ported 3500 heads, BARE
  • Ported 3500 heads, BARE
    $75 for the pair. No valves, rockers, springs etc. Price negotiable.
    In good shape, used. Pics on request. PayPal only. Shipping from 73069 (Norman, Oklahoma). Will deliver for gas costs.
    Email: merlot566jka@yahoo.com
    Phone: 360-471-0684 (text only please)
    2012 Chevy Sonic Turbo 6spd
    Could you post pics? Also, how crazy is the port on them? If I remember correct...i can bolt those to my 3400 bottom end, right? Just have to run the 3500 lower intake and upper intake is optional between 3400 or 3500?
      Will get pics up tonight.
      Porting is not crazy. They were gasket matched and cleaned up. These heads flow fantastic and not much porting is needed. Too much porting will destroy the flow.
      Yes they will bolt to a 3400. You will need a 3500 lower. Which I do not have (I dont think so anyways)
      a 3400 or 3500 upper will work. (not sure but maybe even the 3900 upper will too)
      there is more to just bolting them on and adding the lower intake... provisions for the cars emissions and pcm/ecm requirements are needed as well.
      and these heads are BARE. You will need to source your own valves, valve springs, keepers, locks, retainters, seats, seals, and a valve job. These are not a plug and play set.
      With that said, I am sure all of the OEM stuff can be had for really cheap.
