284 stub shaft
  • Wanted 284 stub shaft
    If anyone has an extra stub shaft for a Getrag 284 that they would part with, I WILL buy it.
    Thanks,
    -Jason
    3400/Getrag 284 5spd
    350/NV3500 5spd
    2014 Chevrolet Malibu LS
    LMAO, i just scrapped one! i really feel bad.
      :shakes his fists at you: lol
      350/NV3500 5spd
        I thought the 4T60E axle was the same length but without the need for an adapter on the driver side. Worth looking into.
          No can do. The stub shaft is a different spline count, and a larger diameter.
          350/NV3500 5spd
            bump?
            350/NV3500 5spd
              probably best to have one made.
                I was trying to aviod that since Im sure itll be expensive.
                350/NV3500 5spd
                  Still need one if anyone has one that they are willing to part with.
                  350/NV3500 5spd
                    Look on Gaoc there was a guy selling a 284 and a few other parts If I am not mistaken his Sig is Domestic kitten
                      The only spare one I have is basically trash after Ben caused the 91 to trash a drivers side axle. I kept it as a keep sake, lol. Best of luck finding a good one
                        Can you post a picture of the trashed one? There are shops that can repair damage and remachine to original condition.
                          I'll try to remember when I get home from work. I never got an alert to a reply on this topic for some reason...
                            Forgot yesterday. It's filthy from sitting on a window sill while doing things like sand blasting, sanding and priming my car last spring. Don't mind the underlayment for my flooring project.
                            The large end is the one that goes in the transmission, the smaller mangled end is the end that goes into the cup on the axle. The cup on the axle broke while Ben was driving the car and the shaft spun inside of it, mangling the small end of the shaft.
                              I remember that. Good ole niles michigan driveway repair.
